Aerox bogging when cold and war,m and even whilst riding
Discussion in 'The Workshop' started by Dom2oo8, Feb 7, 2008.
  1. Dom2oo8
    Dom2oo8 New Member
    Hey i gt an aerox an its boggs down reali bad even wen warm an iwen i slow down for corners i pull the throttle back an it bogss an slows down stupidli so i have to ride it off the choke all the time my air box is all fine but the sponge air fillter is totally wreked so i was wonderin if this is the problem its like not even half of the sponge there
    lemmie now asap thanks
  2. Jamie
    thats probabally why mate, gettting to much air and boggin out,
  3. Dom2oo8
    Dom2oo8 New Member
    ok cheers mate could it be anything else or wud of thought it was that?
    and should i buy a mallosi red sponge off ebay for like 6 quid or would you say not to..?
  4. Jamie
    deffinately buy a new filter element, could be rollers or your main jet
    has the bike got any modifications?
  5. Dom2oo8
    Dom2oo8 New Member
    I dont think it would be the rollers they were changed at december an even with bad rollers its not half as bad as this is yeh its gt a chrome zx exhaust n the rolllers okay then cheers for the help
  6. Jamie
    and youve upjetted when you fitted the exhaust right?
  7. Dom2oo8
    Dom2oo8 New Member
    nope wudnt of thought u needed to the guy who fitted it didnt say anything bout up jetting the carb wat do you suggest?
  8. Jamie
    has the problem been since youve fitted the exhuats?
    if it isnt upjetted then see what jet is in there now, work out 10 percent of it, and add it ontop then buy that size jet and a couple sizes bigger and a couple sizzes smaller
  9. kyle1b1
    10% for exhaust :wtf:
  10. Jamie
    was gona say 5 or 10 percent but wasnt too sure
    better rich than lean ;)
  11. Crana
    Crana Active Member
    Yay someone with the same problem as me! Mine does this every so often... I thought it was the fuel filter but im to lazy to find the filter and I dnt have time atm :( Im going to clean the air filter 2 morro and see if that helps at all
  12. alperin
    alperin Active Member
    aerox 180cc
    hi
    i had same problem if you fit a exhaust or a sports air filter you must upjet your carb this is done by opening the 2 little screws under the carb and unscrewing the little jet and myn was a gurtner carb and it was 62 so i bought 72 73 74 75 and i started from 72 to 74 and 72 gave best performance for me :)
