aerox and sr50 engine the same?
Discussion in 'General Scooter Discussion' started by Sean, Jun 28, 2009.
  1. Sean
    Sean New Member
    ive just bought an S reg aerox, and i broke a V reg sr50 a month or two ago, the engines look similar and i read somewhere they were the same, but the aerox one is in the bike and the sr50 one is now in pieces, before i go selling any of the sr50 bits, are they the same? thanks
  2. Burns
    Burns Active Member
    Aprilia sr50
    yes there the same, what parts you got for sale?
  3. Sean
    Sean New Member
    would practically all the wiring harness stuff be similar too? i stripped some of the engine out (head, barrel, variator, belt, few other bits), but havent yet took the clutch side of it off, and the piston was knackered so i just decided to ram a drill in the crank and lock the engine up that way instead of using a proper locking tool/impact gun
    And also, the centre stand, coil and starter motor should be the same? Aswel as the carburettor? thanks
  4. Burns
    Burns Active Member
    Aprilia sr50
    all main engine parts are the same, mount may be different though, and the loom + coil is different.
  5. BenSRG
    BenSRG New Member
    Aerox, SR50 and the suzuki AY50R all have the same engine.
    The SR50 and the AY50R have the same exhausts aswell XD
  6. Burns
    Burns Active Member
    Aprilia sr50
    only to 2000 i belive? then katana and sr turned to suzuki engines Di-Tech / carb model. yamaha stayed the same
  7. BenSRG
    BenSRG New Member
    actually, sorry burns I think you're right :p
    Apologies XD
