Aerox Accelerating Problems
Discussion in 'The Workshop' started by JamieThorpe, May 17, 2010.
  1. JamieThorpe
    JamieThorpe New Member
    Yamaha Aerox
    Just had a new 50cc malossi engine fitted it revs extremly high ... I have a problem i find it accelrates really well it wheelies when i have just started it but after running for a few minutes it will accelerate really slugish with no power at all ? I was just wondering if anyone knew why this could be ? Thanks.
  2. DUNKMAN
    DUNKMAN Member
    yamaha neos 50
    im not sure why but i find mine pulls away alot faster when its just been started too.
    check rollers,jetting,cluch ware,dirt spark ect i guess
  3. hood
    hood New Member
    mine is also the same but mine gets really bad and slow after a bit acceleration wise even starts to judder the bike, really need to find out the problem !!!
  4. DUNKMAN
    DUNKMAN Member
    yamaha neos 50
    yours could be you rollers making it go slow after accseleration, or a crankshaft problem if it judders that much
  5. JamieThorpe
    Yamaha Aerox
    ok someone told me it could be to do with the belt being tight when cold (hense jsut started) then after running the belt gets warm strenching so it wont grip asmuch in a sense this makes complete sense ? right ?
  6. DUNKMAN
    DUNKMAN Member
    yamaha neos 50
    yh suppose that makes sence ,kevlar belt time :L,, il leave mine i got new rollers and clutch springs and its ok now,,,could be your rollers
  7. JamieThorpe
    Yamaha Aerox
    The annoying thing is mine has a kevlar belt =/ i dont know how old it is though since the ped is 06 and i have owned it for half a year so i ordered a new one and ill see what happens :)
  8. capri dave
    capri dave Active Member
    if it goes well when stone cold but the performance tails off as it gets hotter, then its probably running way rich...
    an engine needs a richer mixture when cold, which is why you have a choke ;)
    if its not over jetted, then the next thing to investigate is the choke....it may be stuck on...
  9. DUNKMAN
    DUNKMAN Member
    yamaha neos 50
    check your exhasut is nto cracked? as it heats up it may expand and the crack may let out more exhaust gas, although this would be noticeable and woulnt affect it this much ,just a guess
  10. JamieThorpe
    Yamaha Aerox
    i think mine must be the running to rich problem as just before i left to pick up the bike from the garage they said they would swap the sports filter back to the stnadered and in about 2minutes they wouldnt of re jetted it
  11. capri dave
    That could well be your problem :good:
    your going to need a smaller main jet then ;)
  12. JamieThorpe
    Yamaha Aerox
    well just fitted a new belt seems worse but will get worn in and will be abit better (probley the same as last belt then) so ill get some jets ordered when i get payed then tell you all how it goes :)
  13. lipsmoker
    lipsmoker Member
    To be honest i think its your choke or jets,
    It runs fine at first because the engine is cold and it needs the fuel from the choke
    once its warm it no loner needs the fuel in your case it sounds like choke isnt turning off, so its over fueling when warm.
    Or if your jets are too bi same reason as above
    Pretty much what dave said
  14. aerox-kid
    aerox-kid Member
    mine did something similar and it turned out it was the clutch and the rollers. Springs in the clutch to soft, and rollers where flat as fuck. If i was you i would check this before you buy anymore parts you don't need.
