aerox 70 malossi v.poorly-help!
Discussion in 'The Workshop' started by cabbron, Nov 9, 2010.
  1. cabbron
    cabbron New Member
    hi all,desperate for some tech help-been without my ride for 3 weeks now and back on my mb :banghead: ,08 aerox,basically left me stranded twice.kit has done about 1500,was professionally fitted,carefully run in,always puto scooter plus synthetic,always run superbly-never abused.
    1st time,revved its nuts off of its own accord- even after turning the key off,then smelt really hot and died.pulled apart,piston good,barrel good,coolant low but no obvious leaks,pump good but temp sender kinda melted.faced up and new gaskets,everything checked,new sender etc.ran for 2 days fine.
    2nd time,just died and water pissed out and a noise as if rad hose had popped off and was flapping about inside front cowl,almost as if the cooling system had pressurised.funny thing was when new sender was fitted the temp light came on :confused: skint help pleeeese.tia.
  2. bertie
    bertie Active Member
    '93 Skipper LX125
    Sounds like the head gasket wasent fitted correctly and has blown, this would cause the engine to rev by itself (airleak), and will be the cause of water pissing out (thats if your rad hoses havent popped off)
  3. cabbron
    cabbron New Member
    thanks for the reply,i have ordered another malossi gasket kit,lets hope its that.weird that after the first breakdown the temp sender had got hot and melted a bit but as soon as i fitted the new one the temp light was on(pre second breakdown)cheers for anymore input.will try another carfully fitted head gasket.
  4. grantmc3
    grantmc3 Member
    piaggio nrg mc3
    take the thermostat out this will keep your cylinder alot cooler
  5. cabbron
    cabbron New Member
    will taking the stat out mean it will take an age to warm up being winter and all?understand it will keep it cooler tho.
  6. grantmc3
    grantmc3 Member
    piaggio nrg mc3
    yes will take longer to warm up but it wont get as hot
  7. bertie
    '93 Skipper LX125
    TBH if you had a shop fit the kit and the bike runs shit and leaks water from the head... Then you already know what to do?
