aerox 70 bogging
Discussion in 'The Workshop' started by AeroxJoe, Jun 3, 2014.
  1. AeroxJoe
    AeroxJoe Member
    1999 Yamaha DTR125
    Hi again,
    So now I got roxy to run, I have the belt off just so it will rev out to check everything etc, slight problem, its bogs on more than 1/2 throttle, I've tried a 72 & 75, basically do I need to go bigger or smaller?
    Spec is
    athena hpr 70
    delly 21mm carb & polini filter
    stage 6 variator 5g rollers
    polini reeds
    Motoforce manifold
    stage 6 pro race exhaust
    polini clutch
    polini belt
    brand new crank seals and bearings
    anyone throw some light on it? I have a 80 90 95 100 & 105 mainjet to try
    one of them do the trick or smaller
    and should I adjust the needle clip?
    Tried fuel/air mixture
    p.s, im running premix
  2. turbovetto
    turbovetto Well-Known Member
    tweaked ovetto
    Hi
    If it bogs with no belt then it could be that the engine is behaving as if it's rich because it's lot loaded by the drag of the transmission. An engine with no 'load' will be too rich - all things being equal. Load the engine and it tends to need more juice.
    Put the transmission on and see what that does. If it's better, then it was that.
    If, however, it's bogging because it's too poor - (it will make a sound like a sheep going 'beeeuuuhhhhh') then that means it's too poor and you need to upjet. . Let it warm up a bit before arriving at hasty conclusions ! ! All engines are poor when they are cold. This is what chokes are for.
    Then try again. Don't do any more testing with no belt. It's not particularly useful - apart from letting you know if it starts.
    Just going on spec I would say start with 90 / 100 with a Polini sponge filter and a DO 21. Possibly a bit more. 110 to be safe, then work down till it pulls. Leave the needle clip in the middle for the mo. It's better to jet big and work down. You can't damage an engine by being too rich.
    If it refuses to behave no matter how big a jet you put in it (and it should be between 90 to 110 depending, with a sponge filter) then you have a leak. These values are ballpark. And virtually useless - but they illustrate a point. It might be great with an 88, but I suspect high nineties. It might be 110 ? Only one way to know. Make it too rich and go down by fives.
    So if it's still going 'beuuhhh' with 120 you know you have a leak.
    Good luck -
  3. AeroxJoe
    AeroxJoe Member
    1999 Yamaha DTR125
    Ive put the belt on, tried 80 90 95 100 & it doesn't even idle properly, full throttle and it does nothing, pm me your number if your free and I'll let you hear
    Joe
  4. AeroxJoe
    AeroxJoe Member
    1999 Yamaha DTR125
    Just so frustrating, tempted to replace the seals again and gaskets, getting annoyed so much :/
  5. AeroxJoe94
    AeroxJoe94 Member
    If you have polini open air filter you will need a jet in bigger than 75
  6. AeroxJoe
    AeroxJoe Member
    1999 Yamaha DTR125
    Yeah ive tried from 72 80 75 90 95 100 105, I've stripped it down and spent more money on seals and gaskets, I out it down to a seal, I HOPE! I also noticed that when I put my finger on the belt and pull/push down the belt goes loose, it has a polini 3g/g3 clutch(whatever one it is) and the standard white contra spring which im gonna replace to the stage 6 one that came with my variator, im a fully qualified car and hgv mechanic and built several motocross bikes but I always found aeroxs to be fundamental
    thanks for your input though pal
