Aerox 100 Tuning Problems!
Discussion in 'Maxiscooter Tuning' started by duckster36, Jun 11, 2009.
  1. duckster36
    duckster36 New Member
    hey guys, I'm trying to fix a problem with my '02 Aerox 100. i recently bored it out to a 120cc and put a malossi multivar 2000 variator in it. Wow what a difference! then a thought PIPE, so i ordered a Technigas Next R pipe, put it on and what a dissapointment! It's real doughy off the bottom and with no throttle response at all. I've put the biggest jets available into the carby but still no difference.
    Should i get a bigger carby and maybe a pod filter to let it breathe? or is there something else I'm missing?
    Cheers Mark.
  2. rt08
    rt08 New Member
    Gilera Runner SP172
    LOL get a better pipe mate :good:
  3. duckster36
    I'm from Aussie and there's not much too choose from down here. found the Technigas pipe on donotlink pedstop site, and they seem'd like a good thing. but since reading a few posts on here I'm starting to get the impression that they're a pretty average pipe...
  4. monty9120
    monty9120 Active Member
    Vespa gts300
    lighter rollers stiffer clutch springs
  5. MiNoR cOnFuSiOn
    fuck all this nonsence about new pipe and air filters...
    the stock jet (i dont know) will be close.. so go up around 10-15%. anything else is ALL down to the rollers and clutch springs.. wont be fuck all to do with restricted air.. restrictions in the airway are GOOD for a 2 stroke carb, it simply ups the pressure inside the venturi.. this is why im running a high spec barrel on the stock airbox.. it works fine and uses less fuel.
    grb ireself some lighter rollers (say a gram or two lighter than the ones you have) and throw em in.. will notice a difference straight away.
    aftermarket pipes dont make power the same way as stock, its all up high and your transmission is set to use low down power you no longer have.
  6. SALVAGED
    SALVAGED Member
    125 typhoon
    what was the comparison in speeds of the 100cc to the 120cc ?
  7. Kieran
    Kieran Active Member
    st
    hardly any difference tbh ;[
