hey all this is gona be my first post since joinin this forum bout 30 seconds ago , anyway my aerox has suddenly stopped workin , first of all it was the petrol filter clogged with dirt from the fuel tank so i replaced that and it worked for about half an hour before ccutting out and now it wont even start , i thought the carb mite b blocked to so i checked that but it seems clean , there is compression and a spark but i hav no idea y it wont start , any help will b much apreciated , cheers
carb hi alex-1966,double check the carb,whip the jets out and clean them,flush tank,lines,check vacumn,is the float in carb sticking? cheers
cheers for the help mate , yeah ive checked all that and the carb seems to be in top shape , ay ideads wahat it could be if not the carb ?
carb hi,try a new plug,failing that somebody that knows more than me will help.cheers. btw wheres hoddy?
Re: carb cheers for all the help mate , i think it might be water in the fuel tank its the only other thing i could think of , hoddys hoddesdon , its in hertfordshire
Hhahhahahaha funny guy. :msn1: so youve completely left out port timings port sizes etc... i tell you what, have a ride on an polini evo 70, then an aerox 100 then come and tell me an aerox 100 is faster.
lol yeh you probaly could make it faster if you had all that money to spend , but whack on a 70 kit wuithout changing gear ratios carb size etc then its not gona make a massive difference
mate im telling you a friend of mine owns an aerox 100 with a zx and is SMOKED by a bog standard jog r with a gear up
I raced an 02 100 rox with an sports pipe on it and showed it the ropes with my standard rox with a leovince pipe my brother had a 100 and he says after having a go on mine he regrets having one
why dont you just let people try and help the guy, we all no they ent too good but he has a problem so help him..... 1. dec-rossi - you put a 2 extreme cylinder and a 33% gear up on your ped, so you dont really no whats going on do you !???!? and..... 2. Crana - your old exhaust fell off (not enough blue-tac) and so bought a leo tt.......
Replace the plug for starter's, drain the petrol tank and refill with fesh petrol take the carb off and clean inside and outside with cab cleaner including the main jet/pilot jet etc
my point being not your not helping his situation are you?? your trying to be big and funny ' oh my ped will smoke yours ' and frankly i dont think many people give a shit...................
this should cover it really, but whilst your checking give a once over on all fuel, oil and vacuum lines and also inlet manifold for any splits if still no luck then report back to us
ok fair enough i int helping, sorry dude and jus for the record the 2extreme kit went on after the gear up and i bought it in an emergency with not much funds
