Advice on front wheel and brakes.. should it just spin?
Discussion in 'The Workshop' started by chris79, Jul 2, 2013.
  1. chris79
    chris79 New Member
    Ok, performance on my 50 isn't what I expect.. derestricted, 4.8g rollers, Endy exhaust, clean filter, .65 main jet... yet it gets to 30mph on the flat and only then slowly creeps to 33/34.. will do 38 downhill...
    So tonight, was pushing the bike with the engine off and it felt like it had resistence..
    I jacked the bike up and the front wheel has to be pushed by hand to make it rotate.. as in it doesn't freely spin. Is this normal?... you can hear a sound like the brakes rubbing or bearings as you rotate it by hand, and I can't help but wonder if there's something up with the bearings or the brakes causing a lot of resistence.. almost like driving with the front brake on slightly.. but constantly...
  2. ramo
    ramo GoldMember
    There should be a resistance it should be slightly free aswell though.. If it gets to 30 or whatever fine then it's probs not the problem
