advice on 125 tecnigas exhaust
Discussion in 'Maxiscooter Tuning' started by t boy, Oct 1, 2007.
  1. t boy
    t boy New Member
    which exhaust is better the standard gilera 125 exhaust or the tecnigas on a 172
  2. Sw1fT
    Sw1fT Active Member
    200SX S13
    stock gilly exhaust.
  3. t boy
    t boy New Member
    what about the giannelli freeway exhaust
  4. Sw1fT
    Sw1fT Active Member
    200SX S13
  5. t boy
    t boy New Member
    are the pm55s any good
  6. Sw1fT
    Sw1fT Active Member
    200SX S13
    yes, if you dont like wheelies
    they are very long.
  7. t boy
    t boy New Member
    would it snap if i wheelie with it
  8. Sw1fT
    Sw1fT Active Member
    200SX S13
    it'll scrape.
    and if u go too far back then yeh, itll snap.
  9. t boy
    t boy New Member
    So whats the best exhaust for a typhoon
  10. Sw1fT
    Sw1fT Active Member
    200SX S13
    depends what u want.
    full on power - pm59
    mild tune - scorp.
  11. t boy
    t boy New Member
    they are for gilera doe
  12. Sw1fT
    Sw1fT Active Member
    200SX S13
    which uses the LC version of what engine?
    drumroll please
    typhoon.
    (any cheeky cunts want to point out mounting differences etc, stfu :p)
    pm59 can go on typhoons, and the scorp goes on with a small bit of cutting of the fan case, nothing major at all.
  13. t boy
    t boy New Member
    are scorps good for wheelies
  14. Sw1fT
    Sw1fT Active Member
    200SX S13
    well i dont think you'd have much luck wheelying a scorp along the road.
    scorps can produce enough power for easy wheelies, but so do stock exhaust, its more technique, and if your getting a 172 kit, wheelies should be easy.
  15. t boy
    t boy New Member
    what about the malossi cdi are they any good
  16. Concept
    Concept New Member
    Get a room you two! :w00t:
  17. Sw1fT
    Sw1fT Active Member
    200SX S13
    lmao
    what about the malossi cdi?
    what setup are you planning?
    leave the cdi till last, then you can atleast see if you need it and recognise the difference it provides.
  18. capri dave
    capri dave Active Member
    no that shouldnt scrape when you wheelie ;)
  19. Sw1fT
    Sw1fT Active Member
    200SX S13
    lmfao.
  20. kyle1b1
    unless you bin it and it falls off :pimp:
