advice needed
Discussion in 'The Workshop' started by h.hubbyy, Jul 17, 2011.
  1. h.hubbyy
    h.hubbyy Member
    JOG R
    hello i have a jog r AC. i have fitted a 70cc polini sport cylinder , polini superspeed variator , polini race belt , 17.5mm carb , better reed block , 70cc exhaust and its top speed is only 85 km/h. any advice on making it faster as i expected more speed with all this kit on :confused: :confused:
  2. RelentlessDan
    RelentlessDan New Member
    have you checked its all fitted correctly and running properly, no leaks or other issues?
    are you jetted correctly to ensure the bike isnt running lean? and is the piston and barrel new, or are they second hand and badly damaged.
    is the 70cc pipe a decent pipe, thats very revvy, which is necessary for a 70cc?
    also, if youve fitted stupidly light rollers then youll lose top speed, but they have to be much lighter than your engine wants to warrant a loss of top speed.
    finally, if its all fitted and everythings as it should be, well then sadly thats as fast as it will go with that setup.
    if you really wish to make it faster, get it dyno'd to see where the bike isnt performing
  3. h.hubbyy
    h.hubbyy Member
    JOG R
    its a brand new cylinder just been run in.
  4. h.hubbyy
    h.hubbyy Member
    JOG R
    4 gram rollers(but its a 9 rollerd variator) 80 jet on a 17.5 carb.
  5. MiNoR cOnFuSiOn
    if the revs are low as you gain speed the rollers are too heavy. if it revs its tits off yet wont move there too light... first thing to check wiht any lack of power/speed
