advanced tuning know how needed!!
Discussion in 'The Workshop' started by nstar, Sep 19, 2010.
  1. nstar
    nstar New Member
    yamaha ROX!!
    wass upp :wave:
    hey every body... im in search of some advice... :confused:cratch: . iv now fitted a kiesler manifold spacer allowing me to place my carb over the rear wheel on my rox.. im using a 21mm dellorto phbg carb.. everything ran sweet as a nut while i was using the carb as the standard layout facing sideways... now it's doesnt run on the throttle at all only starts using the choke for a couple of secs.. i know this is a fuel problem as the choke jet sits at the most lowest part of the float bowl.. if any 1 has fitted the kiesler or stage 6 spacer as these doesnt differ only in design and had the same problem or they know if the carb isnt a recommended 1 for rear mounting maybe a flat sided 1 is needed :confused:cratch: .... any info help or fixes would be MUCH :cheers: appreciated....iv asked on my reguler forums to no responce :banghead: hoping this 1 will come up good :good: thanks...
  2. virginracing
    virginracing New Member
    Yamaha Aerox 2000
    if its not getting fuel then its not the fact your carb is vacuumn powered and you need to suck on one of the lines to draw petrol into the carb to get it running..?
  3. nstar
    nstar New Member
    yamaha ROX!!
    theres fuel gettin in to the carb but it sits in the lowest part of the float bowl. where as the main jet is in the centre as normal so the main jet sits way to high above the petrol leval as the carb is tilted.
  4. SR50JAY
    SR50JAY New Member
    Have you tryed changing the float hight to suit the angle the carb now sits at ????
