Hi there. My name i Kenneth, im 23 years old, and im a Dane. Im nuts about twostrokes (Specially the Hi-Per2 powered Piaggio/Gilera's), and i spend most of my time fooling around with my track-iron, which always seem to be running too great (So i gotta take it apart to find out why :grin: ) Im currently running a Piaggio NRG Power DT '08 as a Daily driver, which has been rebuilt with a Doppler S1R Crank, Stage6 Sport Pro variator, 18mm Weber carburettor (From an old runner), TopPerformances Trophy 70cc cylinderkit and a TopPerformances Powered Exhaust. The track machine started out its days as a Piaggio Zip, then got a watercooled Typhoon engine, and now the engine currently residing on a Typhoon frame once again (Its stronger, more manouverable on the track, and generally more predictable), with an NRG MC2 frontend. The setup is a MetraKit ProRace2 70cc cylinder, 28mm StylePro PWK carburettor, Stage6 HPC crank, Yasuni C20 exhaust, Italkit/Malossi DigiTronic ignition system, Polini SpeedControl vario, Malossi Delta Clutch and an electric waterpump. I look forward to talking about our common hobby/lifestyle and i can't wait to get to know how you do things over on your side of the pond. -Kenneth
welcom to the forum :hello: spec on the typhoon sounds nice.. any pics? anyway i wont waffel on, welcom again, always good to see members from overseas
The only pics i have of it, is from when it was on the zip frame (It got rebuilt last week, and i haven't been arsed to bring the camera down to the yard), but they can be found here; http://noerskov-larsen.dk/scooter along with a few pics of my NRG. The Zip part of it (Which is currently being built as a Stage6 Racing LC 50cc racer) can be seen here; http://www.scootergalleri.dk/html/gal_visbil.asp?ID=239949&ipc=732192 Basically it started out as this; http://noerskov-larsen.dk/scooter/zip/21-1-2009/zip_hentning.jpg And wound up like this (before i got some mods done to the fairings); http://scootergalleri.dk/uploads_xl_wm/2061335.jpg?10-08-2009 03:29:09
should use photobucket or copy the direct link using the /img code/button when you post.. will just show pics in this window then. get some new pics up.. verry interested in this
