im running a de restricted stage6 pro replica exhaust at the moment with my stage6 sport pro cylinder. was wondering if anyone could recommend a pipe that would suit this kit better and increase rpm? ive been told Yasuni c16 or Malossi MHR are ideal? thanks
The pro replica was pretty much designed by stage 6 to be used with the sport pro cylinder :good: you may get a very slight advantage if you change to a c16 pipe, but the problem then will be, the c16 is designed for cylinders with harsher timings than the sport pro :glare: i would be inclined to stick with what you got, because c16's arent exactly cheap, so its a lot of money spent for very little power gained.... unless you was going to buy a stage 6 racing cylinder kit (or equivalent from another manufacturer) then the c16 would really start to come into its rev range :grin:
