A Hi, & Help!! Ive been screwed :(
Discussion in 'The Workshop' started by Darkstar82, Nov 4, 2012.
  1. Darkstar82
    Darkstar82 I own a speedfight. Much grumbling.
    SpeedFight 2 100CC
    Hi all, first post here now Ive found a decent place to ask, took some digging around Google to find the largest scooter forum. :)
    Ive recorded my message in Vocaroo... easier to explain by listening rather than typing an essay to bore you to death with. Will type replies. :)
    And thank you to anyone who responds, its appreciated.
    Just click play and listen, thanks for your time.
    http://vocaroo.com/i/s0OXzp2XCTNA
    Bike is a peugeot speedfight 100cc air cooled, two stroke engine. 2008.
    p.s. full parts list ive had at present:
    brake pads front and back
    column bolts
    new tyres
    reed valve
    float needle
    exaust bracket
    indicator cover
    new battery
    new front shock (previous was near ruined)
    now also require a carb. not flange joint.
  2. JamesC
    JamesC Member
    Speedfight 100
  3. A-LY
    A-LY Active Member
    http://www.pedparts.co.uk/product/403/tnt-tuning-race-carb-19mm-21mm
    i reckon this could work, just check your existing fittings to make sure it fits.
    column bolts, find what size and thread they are and go to a shop that specialises in steel kinda stuff, it'll be cheaper than b&q or homebase.
    tyres, look on gumtree or ebay. i scored a whole wheel for my aerox for £15, which included a nearly new pirelli tyre.
    exhaust bracket, depending on whats wrong with it you could get welded up if its snapped
    brakepads, ebay, i got both front and back for about £20
  4. TeeZer
    TeeZer Member
    R1, DNA 50
    Flooding is more than likely float level or needle valve (not the long needle on slide) and seat. Take carb off check all pipes passages are clear (blow through them). Take bowl off and check float, if worn or has a hole replace it. Check float level, find out correct measurements and if all looks good. Try the needle valve and seat. You could get a way with just stripping and cleaning out the carb. A needle valve and seat kit costs around £8-15 depending on carb, they also come in different sizes. This is a fairly easy job with plenty of youtube vids. Remember, you cannot break what is broke! Go for it.
