A bit lost now
Discussion in 'Bike Chat' started by 2many2strokes, Mar 23, 2012.
  1. 2many2strokes
    zzr1400
    Hi
    Ive got a old 2stroke kh125 that will not run, its been sitting for a while been restored. the frames all complete but the engine just wont go :(
    Has Fresh Fuel and oil (pump works)
    Clean Carb no air leaks
    NEW ignition timed with strong spark
    Good compression
    But still no go!!
    Any advice would be great just want to get it out the shed at last!!
    thanks
  2. Jonnymarrw00t
    Piaggio Zip 05 plate
    do you have a compression tester ? and also a spark tester ? Because even if the spark looks good out of the bike. It can be really weak under compression.
  3. 2many2strokes
    zzr1400
    Yes tested the ignition with spark plug tester and read 118psi on compression o_O
  4. Jonnymarrw00t
    :confused: is fuel getting into the engine ?
  5. 2many2strokes
    zzr1400
    wet plug and i did try putting a spoon full of premix down the plug hole just in case. I did have the engine running a few times only for a few seconds on full throttle but it wouldnt rev and just cut out.
  6. Jonnymarrw00t
    sounds like idle to me then
  7. 2many2strokes
    zzr1400
    ive played with that as well got my mate to have a muck about with it, hes pretty good at carbs spend most his time fiddling with them on the mexico. i think i might give up on it and get a new lump for it
  8. Jonnymarrw00t
    It can only be fuel/ignition/compression :/ Does your fuel tap work properly ?
  9. 2many2strokes
    zzr1400
    I checked there was fuel coming from the tank to the carb, there is. checked the float valve was working fine, it was all jets are clear all seals on the carb are good. this has really stumped me :(
  10. Jonnymarrw00t
    Knowing your luck it's something really stupid :/ Are the reeds leaking ?
  11. 2many2strokes
    zzr1400
    it doesnt have reeds it has a rotating valve
  12. Jonnymarrw00t
    I don't know then I'm afraid :/
  13. 2many2strokes
    zzr1400
    ok thanks anyway
  14. Stig
    Stig Well-Known Member
    EXUP1000
    When my EXUP has been stood its a bitch to get started. It'll fire for a second or two and then stop and as you say its wont rev.
    Try dumping it down hill, it clears things out....
    Spose the KH is kick start only????? (been a long time since I saw one) but if its electric, stick a jump pack on the battery. The engine needs a good 14.4V to get started ideally
    always works for me.........
    Have you tried eazi-start down the inlets?
  15. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    Could be ignition timing?
  16. Stig
    EXUP1000
    if the ignition was OK before being laid up then it SHOULD be OK now. By the age of the bike it'll prob be points as opposed to electronic.
    My mates RD250 (1979 V reg) was points and they slipped whilst he was in a shop. He came out fired it up, dropped it in first and reved it to pull away and the bike went backwards. If i'd not seen it for myself I wouldnt have believed it
    still recon its clogged up with stale fuel IMHO
    I'll let you know tomorrow if mines the same as I've just got it out its winter storage bag. Few bits to swap and sort first tho'
  17. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    Choke working ok ?
  18. 2many2strokes
    zzr1400
    ive changed it from points and condenser to a electronic ignition. company in germany makes conversion kits for old bikes. never liked points always fucking up. Yes the choke is working as well. It did run for a little while on a squirt of easy start but it hasnt run since.:mad: Think i might need to just strip it down completly. spoke to a guy from work who use to have one that the rotary valve plates wear out creating a air leak. Ive got thescoot so its not the end of the world if it takes a bit longer.
  19. creamsodauk
    creamsodauk Ped Ped!!
    Runner 125 SP
    sounds like an air leak to me. running only on full throttle would suggest it needed alot of fuel to even out the massive air leak to get it just to run
  20. 2many2strokes
    zzr1400
    I Have thought that as well, just got a whole new gasket set for the bike will have to work day and night now to get it running. My ped last night decided to shake itself to pieces and catch fire while riding LOL
