70cc kit
Discussion in 'The Workshop' started by callum, Sep 28, 2009.
  1. callum
    callum New Member
    Hi I am wanting to get a 70cc kit but I am not sure witch one to get; I would like something reliable because I am going to be using it for college three days a week.
    I have a Piaggio NRG MC3 2003, it is standard apart form a Leo vice TT sports exhaust and the rollers that come with the exhaust. Will I need any more things of it?
  2. typh-gilly99
    typh-gilly99 Member
    Typhoon 125 2T
    there are many posts which will answer your question...however, i would go for the polini cast iron kit, upjet the carb, use a standard airbox if you got a standard carb and add stiffer cltuch springs.
  3. callum
    callum New Member
    So will this make my scooter faster and with better acceleration? I have read on other posts that you should get a bigger carburettor? 21mil or something like that.
  4. Ty70cc
    Ty70cc New Member
    Typh
    Get A Malossi Or Polini Iron Cast Kit Depending on your budget,a 21mm carb you cant go wrong just be sure to up-jet it correctly and if you can you'll see the difference in the acceleration instantly, i would get a new variator and belt if i was you
  5. bait
    bait Active Member
    yea a 21mm carb is another good extra
  6. gregzzz
    gregzzz New Member
    nrg
    21mm is abit overkill IMO for a cast iron kit... Standard runner 125 carbs.. (20.?) correct me if im wrong can get for under 40 quid
  7. bait
    bait Active Member
    20.5 i believe yea stock runner/typh/sr carb will do fine and cost less
  8. Ty70cc
    Ty70cc New Member
    Typh
    loool i forgot im talking about the iron cast i was thinking about the mhr rep 70 kit this was the setup i had for my typhoon 70
    mhr 70cc kit
    bgm bearings
    mhr team pipe
    polini evo crank
    polini straight manifold
    polini evo reed block
    polini kevlar belt
    polini super speed variator with 6 3.7 gm and 3 5 gm rollers
    black deloroto 21mm carb
  9. gregzzz
    gregzzz New Member
    nrg
    whats so good about the black version of the 21mm
  10. Ty70cc
    Ty70cc New Member
    Typh
    Dunno Just Looks Nice :) and i heard before they was limited edition
  11. callum
    callum New Member
    Right so i should get:
    -Malossi Or Polini Iron Cast 70cc Kit
    -stiffer clutch springs
    -upjet or better carb
    -new variator
    -new belt
    would i need a better crank shaft?
  12. Ty70cc
    Ty70cc New Member
    Typh
    u dont really have to get a new crank depending on how many miles the engines gone over but i'd defo go for a new crank and new bearings :) id defo go for a malossi kit 2
  13. callum
    callum New Member
    Where is the best place to buy these from?
  14. Ty70cc
    Ty70cc New Member
    Typh
    Scooter Attack Or Scooter Center
  15. Yam-Aerox46
    Yam-Aerox46 New Member
    hello callum just wondering what college you go to, sound familiar lol.
  16. callum
    callum New Member
    I go to gateshead college (newcastle tyne and wear)
