70cc big bore kit suggestions
Discussion in 'The Workshop' started by r0ck1s, Jul 30, 2020.
  1. r0ck1s
    r0ck1s New Member
    i am looking to install a 70cc kit on my runner sp. i read that the due plus is a really solid kit and i am between that and the stage6 streetrace kit. i am looking for reliability and power. thanks in advance
  2. Stevep
    Easy do 55 on a standard de-restricted runner
  3. The Messenger
    The Messenger Active Member
    sorry have no experiance with the due plus cylinder... but I do rate the stage 6 street race.
    I fitted one some years ago to a lads runner, and i was quite impressed with the quality and performance for the money.
  4. r0ck1s
    r0ck1s New Member
    i have read some good feedback about the stage6 streetrace cylinder. i will be probably installing that one. my top speed is 101km/h on a downhill type road. on a straight it does 95. it is already pretty good for my setup: rms reinforced crankshaft
    standard 50cc cylinder with a prox piston
    polini speed control variator
    5.3g rollers
    malossi flip homologated exhaust
    malossi belt
    malossi clutch springs
    modded air box
    malossi white contra spring.
    a lot will change obviously with the new cylinder. i will keep you posted
