52/54/55
Discussion in 'Maxiscooter Tuning' started by stevegti2, Dec 22, 2007.
  1. stevegti2
    stevegti2 Member
    hi people been deciding on crank for piaggio 2t lump and really my question can onley be answered from experiance have heard alot of 55mil cranks dont let the engine rev hard enough was wondering what people with them think
    cheers steve
  2. MiNoR cOnFuSiOn
    no they dont.. useless with a stock/unported barrel hence the bad reviews by mechano builders ;)
  3. stevegti2
    stevegti2 Member
    cheers that makes sense as i dont want to port the lump yet will prob go for 52 malossi or bgm
    much appreciated steve
  4. stevegti2
    stevegti2 Member
    sorrey another question im not a 2stroke geious what is the squish and how is it mesured at a guess id say the space beetween piston and head at tdc using a dial gauge but i might be wrong
    cheers steve
  5. MiNoR cOnFuSiOn
    ye.. but a dial guage is kinda hard as you have to know the hight of the head... just use solder messured with vernier calipers..
  6. stevegti2
    stevegti2 Member
    what do i do with the solder sorrey
  7. MiNoR cOnFuSiOn
    in the plug hole to the cylinder wall and slowly turn the engine by hand on the flywheel.. it will squish the solder and that is the distance
  8. stevegti2
    stevegti2 Member
    arhhhhh clever and simple cool on the other hand how much is mild porting onley on the cylinder anyone know
    cheers steve
    thanks for help minor confusions dude much appreciated
  9. MiNoR cOnFuSiOn
    i do correction for the 55 stroke for 100 ;)
  10. stevegti2
    stevegti2 Member
    by correction what do you mean exactley i was also gonna use a billet head of somesort but not sure on which one thats why i was asking about squish and cureiosity.
    cheers steve
  11. MiNoR cOnFuSiOn
    head works when corrected verry well... and by corrected i mean the port hights to match the stroke
  12. kyle1b1
    yeam am guessing anything over the standard 52 will.
  13. MiNoR cOnFuSiOn
    if your changing the stroke of a crank the ports made for a 52 will be wrong..
  14. MiNoR cOnFuSiOn
    54 with no work=less power
  15. stevegti2
    stevegti2 Member
    i think i understand u now minor
    example [bare in mind this is an example im sure youll get it ]
    you have a 1.3 ford cvh engine and bolt o a bottem end from a 2.0 mondeo not much point with this head as your not using the full potential of it [you may or may not get this this is the sort of tuning im used to 4cyl 4ts
    cheers for all yous help and info will get in contact when i wanna have my engine matched etc
    thankyou steve
    p.s [ the 1.3 cvh head is compatable to that of the old durated 2.0 and many other bottom ends as ford are lazy bastards and used that engine in like everything ]
  16. stevegti2
    stevegti2 Member
    p.s the word durated in my last post should say duratec
  17. wobbly_trials
    pretty much, the valves and ports in the 4t head wouldn't cope, just like the ports in the 2t cylinder wouldnt be up to it, although the position of the ports is the crucial factor on a 2t whearas on a 4t its more down to the size
  18. stevegti2
    stevegti2 Member
    yeah but the position when increasing the stroke on a 2t is fixed by the packer plate i guess where as in a 4t its simple on top or no where lol :cool:
    steve
  19. wobbly_trials
    yeah, unless you get the die grinder out.
  20. stevegti2
    stevegti2 Member
    and im confused again lol
