28m carb
Discussion in 'General Scooter Discussion' started by runner172, Nov 4, 2008.
  1. runner172
    runner172 Member
    will a 28mm carb off a aprilia rs 125 fit on a gilera runner 172 and will i have 2 do any fink 2 it 2 make it fit ????? :wtf:
  2. icerider50
    icerider50 New Member
    yeah it will fit m8 u have to buy a bigger inlet and take the throttle cable arm off ur old carb and cut ut down to make it fit if not try and get hold of user name sleazephoniks cause he put 1 on his 70 typh and ask him
  3. alex_1966
    alex_1966 New Member
    youll also need to use the rs's manual choke
  4. baz172
    baz172 Member
    you'll have to change the main jet to around 108 ish , get an inlet manifold i used a pm tuning one for 25mm but it works fine but i think you can squeeze it in to a standard one if you put it in hot water for abit, get a flip up choke unit mine cost about 6 quid , oh and watch out for float bowl rubbing on the cases i've shoved a bit of rubber where it rub's so it wont wear through the float bowl , and thats it sort of just have to fuck about with jetting for your bike but mine runs sweet made big difference
