ive had a look for this question but cant seem to find anything about it well basically whats cheaper. buying the 25mm carb, that comes with inlet manifold reedblock and filter. i think its 200 or buy it all seperate, reccomendations for the best parts to use would be appreciated as im sure the complete kit doesnt have the best everything imp: cheers
not sure if there's alot of places that sell the 25mm seperatly, they like to sell them off as malossi or polini. but a 28mm is £55? manifold £30-35? mhr reedvalve £35? hope that helps
25mm from ve is alot cheaper than the so called malssi or polini ones there all dellorto so i dont see the difference i had a 28 off a aprillia and must say felt better than the 25 in mid but nirther were pro set up steve
i just got a letter saying im getting £200 from my smash last march hmm 172 or 25mm imp: . i will get both anyway
30mm needs a hell of alot of throttle travel, needs a qa throttle just to get to full throttle. anything over a 25 is a waste of power on a piggy block as they only flow through a 25mm hole, you will just lose low end power but gain some top speed. cut the skirt of the barrel and the 28 makes a big diff.. enlarge the stub an the 30 will make it fly.
should never be a "need" portwork makes your balls grow, so do it p.s yes i am fucked and no i dont care
