25mm carb question
Discussion in 'General Scooter Discussion' started by rideorcollide, Dec 12, 2008.
  1. rideorcollide
    rideorcollide Active Member
    TYPH 172
    why does my 25mm stick???
    it happened to lol aswell, both the cables and splitter are fine ???
    its got stuck closed before aswell.??
    im propa confused, someone help please :pimp:
  2. mhr-typhoon
    mhr-typhoon New Member
    mine does it aswell it you get a tiny bit of grit between the slide and carb wall
  3. lukeyboixrace
    lukeyboixrace Member
    my standard 12mm carb was sticking the other day.
    for some reason, if i turned the idle up a bit, it would stick and couldn't throttle it, if i unscrewed it the tiniest bit it would unstick and be fine, but it would idle pretty low, so i don't really know how i can put the idle up now :wtf:
  4. rideorcollide
    TYPH 172
    :wtf: carbs are strange man, my slide looks pretty scored so im gonna go and get a new one today and see how it goes, new cables aswell while im there..
  5. bait
    bait Active Member
    do you ever find when you turn your steering to the right as far as it goes the bike starts 2 accelerate?
  6. capri dave
    capri dave Active Member
    throttle cable trapped or not routed properly...
    turning the steering should not affect the throttle cable at all...
  7. capri dave
    must be grit or something getting past your air filter into the carb...
    I would hazard a guess your running an open filter ;)
    if its a sponge type filter and not oiled, fine particles of dust/grit will penetrate
    the pores of the sponge!!
  8. MiNoR cOnFuSiOn
    probably the pip in the wall of the carb.. its ether nylon or metal. push it back in the carb from the outside, if it is all the way in and still sticking then you need to replace this lil bit. find a dellorto carb stockist... (bell a webber shop an they will usually grunt and give you a number)
  9. wobbly_trials
    my derbi one used to stick open, turned out it was freezing, i made a duct from the exhaust to get the hot air around it, worked a charm.
  10. bait
    bait Active Member
    do you mean like normal 2 stroke oil or what?
    what oil do you recommend?
  11. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    A smear of 2t work fine ;)
