just got a 25mm carb and no were to put my vacum pipe from my petrol tap to.. can some body please tell me wot i am ment to do. will it be o.k to just remove the vacum pipe from my petrol tap as i have no were to put it or not....please any help..
you will either have to drill a hole in carb for a nipple for the hose to go onto or get a t connecter and join the vacum tube into the vacum tube comin out of the cases under the reed block
lee..cheers mate for that. i did go to a shop to try and get a liitle nipple for my carb but the bike shop i go to dont sell them no more. would you no were i could get one of these nipple from vif nit im just gonna have to do wot you said use a t-connet and fit it that way...once a again cheers for da reply mate..nice one :thumbsup:
you could use one of the brass nipples off a standard carb if you have one but personally i would just get a t piece its easier and does the same job
difference between the carb vacum and the pum p vacum is its relativity to the reedblock. the pump needs a suck and blow (gets positive and negative pressure from the engine) the carb simply sucks as the reeds halt any pushing action.. this isnt a problem untill you look at how fragile a diaphram inside a tap is. it will soon break down if fitted this way unless you fit a one way valve (again readily avalable from anywhere that stocks the t peice usually) but ye, find a stock carb, pull a vac fitting out of it wiht a pair of plires (they do just pull out wiht a wiggle) drill a hole in your new one slightly smaller than the fitting and hammer it in.. done.
em,,,,,guys the thing is i havent got an old carb so im f**ked ther. so i mite have to do it the t-pipe way untill i can gat a nipple. does any of you no were i could pick a t-connet for now...
if you really wanted to you could get a metal t piece and cut one bit of it and use that for a nipple
o.k,,gonna go to halfords tomorrow and see wot i can fined.. but cheers (lee) and (minor) for the help will be back tomorrow to let you no how i got on....cheers guys....
hi guys iv got a t-connet today from a auto car shop and conneted the vacum pipe that comes from my petrol to the vacume pipe that cumes out from the side of my manifold..so am i right thats all i have to do for now untill i get a nipple and fit it to my carbs..
no.. connect the vac from thne tap AND the vac from the pump to the t peice then use a small peice of pipe to the vac fitting under the carb... if you get another fitting you dont need the t connector
em,,minor. i got a 3 peace t-connect today and the black vacum pipe that cumes off my tap i fitted to the 3 peace connecter then the other black vacum pipe that connects to the manifold under the carb i cut in half so i was left with abit off black pipe still left connected the manifold and the other peace of pipe that i had cut in half so wot i did is connected them to the t-connecter...doas that sound right to you..... please tell me iv done it right..
yes.. 2 into the one vac... but theres still no one way vlave so it will work, yet fuck your fuel tap.. is it me or am i saying everything 3 times in every post recently?
You know what the admin team should do (minor, lolz). You should research all the most recently asked questions, and acutally do locked topics about them, and discuss how you do it etc, that will stop 3 things. 1) Multiple threads like this. 2) you moaning about the multiple threads. 3) them moaning at you about you moaning.
No it wont. People don't search and they don't even look. However I have just thought of something that might help so watch this space?!
As I said it wont work. How often do you see someone making a new topic about something that's been posted about 3 topics below? All the fucking time. The most asked questions are endless. Everyone thinks their question is some how slightly different. Even if it's covered in a guide already. E.g. all the topics on jetting that could be sorted by people reading minors guide to carbs and jetting. Even the mod I put that gave you 10 topics just like the one you were making every time someone puts up a new topic. Didn't stop anything. Anyway like I said... Working on something.
