25m carb pre mix setup and help? is it worth it?
Discussion in 'Maxiscooter Tuning' started by jammy typhoon, Oct 16, 2008.
  1. jammy typhoon
    jammy typhoon New Member
    ok i might buy a 25m carb pre mix but what do i have to do exactly to run pre mix? take of the oil pump and belt? do i jet it the same as a normal carb?how will i know how much oil to put in the petrol tank? do i have to put oil in each time? is there any gains from running pre mix? only thing i can see being difficult i to much oil it will run boggy and to little it can seize?
    sorry for all the questions
  2. WOLFFY
    WOLFFY New Member
    you dont have to take the oil pump off.
    Take off the inspection cap I think it's called?
    And there is a cable round a semi-circular bit of metal.
    Just unhook the cable and job done.
    Ratio is 50:1
  3. nibbles
    nibbles Active Member
    search
  4. MiNoR cOnFuSiOn
    why would you run premix with the oil pump in place? point is you DONT wasnt the engine driving the thing.. take the fucker out :confused:
  5. WOLFFY
    WOLFFY New Member
    Well I never had a problem when I done it....
    No oil cable = no oil....
  6. MiNoR cOnFuSiOn
    no shit shirlock... so why bother not taking it out..
    it TAKES POWER, YOU RUN PREMIX TO REMOVE THE PUMP FOR POWER. you have lost the advantage with fuck all gain.. is this making sence yet? LOL
  7. jammy typhoon
    i know what minor means.. its takes the crank power to move the oil belt, if your running pre mix you can take the oil belt of and it revs more freely? am i right minor confusion? and will u notice a difference?
    and when i take it all of do i need to poor oil into the crank before i start it? since the petrol in the bike wont have oil inside it?
  8. MiNoR cOnFuSiOn
    put some oil in yes... plug hole will do and run the petrol 50:1
  9. baz172
    baz172 Member
