21mm pwk on polini evo rox
Discussion in 'Scooter Tuning' started by pimped_aerox2, Sep 2, 2008.
  1. pimped_aerox2
    pimped_aerox2 New Member
    right at the moment i have been trying to run an evo like it runs but boggs out up to bout 20 then rele goes and just all in all doesnt run smoothly at all now is this becuase i have a 21mm instead of say a 28mm would sort of difference would that make and can anyone recommend anything else to try cause having trouble selling it
  2. MiNoR cOnFuSiOn
    ok, first off your having lots of troubelw ith this as your diagnosing your prob wrong, get an ajustable clutch and wind it up, get it so the wear is even then ajust equally tighter and tighter till the takeoff rpm is in the powerband of the barrel.
    the carb isnt your prob, the fact the evo makes fuck all power untill around 9k is. your clutch is set to bite WAY to low in the revs hence it engages then you have to literally gain speed to gain rpm till the power kicks in. fuck all to do wiht the carb altho its easily mistaken, same with rollers...
    get your carb rich (refer to somone elses setup) then set transmission... once its pulling and revving as it should you can set the carb up.
  3. RY4N172
    RY4N172 New Member
    What carb was james running on his minor
    and what setup was he roughly running to give owen a rough idea.
  4. pimped_aerox2
    cheers mate cause i would like to run this evo but at the moment i dont see its worth it because i need to work out how to get the ped to have torque etc and run smooth not like its going to fall to pieces any second etc
  5. Dec
    Dec Active Member
    nothing ugm
    build the motor and give your bike to somebody with a clue ;)
  6. MiNoR cOnFuSiOn
    evo = high revving setup... it wont go bang, dont panic. its ment to do those rpm's...
    james had a 25 but its a piggy, wouldent have a clue with a rox especially with a copy'd pwk. orible things.
    just set it rich (whatever that is) and get the clutch/rollers right, it revs RIGHT up befor moving, this is normal. dont be scared, you will appreciate it when its right, probably lookin sub 3g rollers in a rox (total specualtion) but the piggy's ive done have run as low as 3.7g rollers... says it all i think
  7. pimped_aerox2
    thanks very much minor at the moment i have 3g in there so i need to get a decent clutch so that when u rev it. its already at 9000rpm because at the moment when u rev it on tick over it doesnt sound smooth its just like dull if i was to change the carb wat would you recommend
  8. MiNoR cOnFuSiOn
    dont do rox's so fuck knows... a REAL pwk 28 is the usual choice (not a bgm/stage 6 one as there pritty shoddy tbh)
  9. pimped_aerox2
    who are they made by cause theres a few pwk ones out there like the koso one etc
  10. MiNoR cOnFuSiOn
    all made poorly in india for about a quid a go... dont waste your time.
    just find a real one on ebay or stick with a dell.. there more ped friendly to setup tbh. dont get mer wrong the pwk's are fuckin great carbs but deffo not the easiest to setup/find bits for
  11. Aerox-lad
    Aerox-lad New Member
    a m8 of mine is running an evo 2 wid 3.2 g rollers.
  12. MiNoR cOnFuSiOn
    theres a million variables.. basicly get the clkutch sorted, then rollers, then fuck about with the carb,m you WONT get an accurate carb reading with the transmission un set
  13. pimped_aerox2
    tbh we all know that how high the evo revs and i dont know about anyone else but i reckon it revs well to much for the road.
  14. Dec
    Dec Active Member
    nothing ugm
    course it dosent,
    think of a honda rs125 or a tzr 125/250 or aprilia 2t, they all rev around the same as an evo if not more.
  15. pimped_aerox2
    tbh i now need my ped to be able to get to work and back 3 days a week and i dont reckon the evo can handle it to much hassel of things braking etc
  16. one7twoboi
    one7twoboi New Member
    get some vids of ya ped then. sounds quick by the look of things :D
  17. pimped_aerox2
    dont get me wrong it is quick and i do like it but my mates running a polini sport setup and its brillent loads of fun to ride and hes on it day in day out it never braks down my evo was also braking down and just cause me hassel to setup and its still not right yet it shit tbh i just want something that power wheelies and hits round 70 now i have had enough after constant spending and nothing going right
  18. MiNoR cOnFuSiOn
    a honda rs is a track bike.. the tzr nsr and aprilia are lucky to see 13k.. the evo can hit well over this
  19. Dec
    Dec Active Member
    nothing ugm
    i thought evo revved to about 14.500 rpm peak?
  20. MiNoR cOnFuSiOn
    no, peak power is rated at 14.5... depends entirely on the pipe how high it go's.. 14.5 peak is a little diff to 13000 MAX tho isnt it. max rpm with an evo crank combi is 16+k ;)
