I only see one. Can you get a pic and circle the a/f screw? The only one I see is the one that raises or lowers the slide...
There should be one with a spring which is the idle screw the other will be a small screw which is the air fuel mixture
The air fuel mixture screw is fairly flat to the carb you will be able to notice the difference between the 2. idle mix has a spring on the screw the air fuel mix does not
Yeah you have to use a flat head screw driver to adjust it. usually screwing it in will richen the mixture screwing it out will make the mixture leaner
Usually its all about trial an error as i've found out before. But try to get the engine running as fast as you can throttle wise with the air/fuel mixture screw. No one can tell you the right set up dead to the point if you no what i mean.
You should adjust it when the engine is fairly warm rather than when its cold then you will be able to tell the difference
