Right, Have had a look through the 125 tuning guide. Not too sure if the same principal applies to a 180. Current set up is PM59 Open filter w/ jetting to suit, Was told by a pal that 180 with PM59, 25mm and stiffer clutch springs is just as quick as a 172? I'm deffo getting a 25mm carb kit and a 172 kit, just not sure which to get 1st? I'm thinking along the lines of getting the 172 then getting the carb as means will not have to faff about with the jetting? Also going to be getting a Malossi CDI as well soon. Any tips would be appreciated. Thanks.
Take it you`ve got the std 20.5mm Delorto, and a std-ish 180 set-up (barring the pipe). Just my opinion but I would fit the 172 kit first, the porting is more agressive and the head is 10.5:1 comp against the std 180 head of 9.8:1 approx. Dial this in on the old carb, run it for a while then fit the 25mm Delorto and dial this in. Youve still got to dial a carb in twice but only have to dial in the 25mm once. Don`t bother spending money on a malossi CDI unless you`re going hi-end porting and revving over 8700rpm, the only difference between that and std is the retard timing at high revs, bottom end and normal street use the std CDI can cope well (ran one on the strip for ages with no problems).
Thanks for the advice. Will go for 172 first then carb and forget the CDI. As for the Malossi secondary gearing, what is true top speed it will allow and what will 180 gearing allow? Thanks again.
Lol! I quickly edited that out when I realised you`ve got the 180, should`nt worry about gearing it up with the 180 box but as a matter of intrest the ratio`s normally go (from lowest to highest) Std 125 box Std 180 box Std 125 box + malossi secondary Std 180 box + malossi secondary So youre 180 box has a higher ratio than the std 125 box but lower than a Std 125 box plus gear-up. It`s a common mod for the 125`s to swap to 180 gearing rather than go Malossi but you`re already there.
so much for keeping and untuned ped for reliability......lol or was that your brother who said that?? lol go fucking nuts with it!!!! buy some 125 cases, send them to mrt for work along with the barrel and then fit whatever part you can find with malossi/polini in front of it on it aswell should be quick and fun oh yer and once its all done, buy some life insurance for the misses
lololololol 'twas me who said it. Yeee, deffo needs 172. I miss my old shit piece 172 now was ALOT quicker Oh well.... this one will be better though when I'm finished with it... Oh yee, alex.... AXA any good?
where does everyone get these 172's? we have no such thing in my country! I have an elephant though :wtf:
https://www.pmtuning.co.uk/Merchant...ct_Code=04-M3111140&Category_Code=002RUNNERFX I bet your misses loves you.
my 180 jus had a 25ml carb and pm59 and openfilter...jetted to suit and i was leaving 172 allday long at enfield ask jj180...dont put a 172 kit on a 180 please
