125vx
Discussion in 'The Workshop' started by Jamie, Feb 29, 2008.
  1. Jamie
    hi, basically my freind has one, and recently after driving for abit it just conks out , comepletely clutch disengages and everything,, he had a look at the transmission and apart from a few teeth missin of the front pulley it seems fine, although the variator shaft does have some play, like you can push it in and out about 3 mil. and the clutch assembley moves up and down slightly, also when running there seems to be a rubbing noise coming from the transmission...
    anyone know what it could be??
    thanks for any help :D
  2. monty9120
    monty9120 Active Member
    Vespa gts300
    the play in the crank is normal.
    i think the more worrying thing is the clutch is moving up and down. thats what the rubbing is
    running problem, is it from any speed, if the bike is going slow then the force of the clutch could conk it out as it doesnt take alot to stall a single 4 stroke
    also the ht cap sits on the plug so it may seem like its on but it may not be properly
    or a stiff valve :bird:
  3. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    the 4 stroke see a 2 stroke and shit itself and played dead lol obviosuly sorry j decided to play ur part n spam lol
  4. runner 180
    runner 180 New Member
    jj you joker this happen with my runner sp the gears was dodgey and had a lot of clutch play swap it and the gears sized on the boy. if that any help
  5. connor
    connor Active Member
    ahaha about time bradley myt decide 2 get a nice 2stroke now :D
  6. monty9120
    Vespa gts300
    or just sort out the bikes hes got :bird:
  7. connor
    na you dont know the boy he hasnt had much luck with peds what so ever he his more likely to stick with his rs 125 or sell both an do a 172 :bird: :bird:
  8. Jamie
    any more ideas anyone?
    thanks
  9. Jamie
    How do we check for a stiff valve?
  10. monty9120
    Vespa gts300
    get a haynes manual. and strip off the head
    i would take it to a garage myself
    obviousely make sure the other things i put have been checked
  11. *James*
    *James* New Member
    :bird:
    You take everything to the garage :D .
    Home DIY FTW.
    Only joking, dont mow me down on the 4stroker :emb: :nerd:
  12. monty9120
    Vespa gts300
    im all for home jobs
    tbh i know nothing about the top end on a 4 stroke. well not to fix them anyway
  13. kyle1b1
    then you do not deserve that sig :bird:
  14. monty9120
    Vespa gts300
    i do i do
    i could possibly do a top end on a 4 stroke. if i need to ill do my next one
    if im honest i cant be fucked lol atm,
    i cant be bothered to fit a 172 to the drag but i suppose i will have to lol :w00t:
  15. kyle1b1
    yes you will :pimp:
  16. Jamie
    ill fit it then you lazy bitch :pimp: :bird:
