1/4 turn throttle
Discussion in 'Wanted' started by WOLFFY, Sep 21, 2008.
  1. WOLFFY
    WOLFFY New Member
    As title says.
    Or if you know of anywhere that sells them.
    Thanks.
  2. one7twoboi
    one7twoboi New Member
    Scooter centre ;)
  3. alex_1966
    alex_1966 New Member
    yeah serch scooter center , sip or scooter attack for a fast action throttle , theyve all got them ;)
  4. alperin
    alperin Active Member
    aerox 180cc
    wat does it actually do?
  5. WOLFFY
    WOLFFY New Member
    Found the one I'm after on S-A... Dont have any in stock.
    They have them on S-C but not the type I'm after.
    Want the one where you can see the cable..
    The "Vertical" model I think it is?
  6. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    whats the actual idea other than quater term as in advantages disadvantages
  7. WOLFFY
    WOLFFY New Member
    Opens the throttle quicker.
    Throttle slide opening quicker = Quicker accelration??
    Some times you have to twist it, then twist it again.
    The look pretty cool on bar kits??
  8. kyle1b1
    yeah usually helps when have a big carb and takes a few turns to fully open the throttle and on sum carbs wont open the throttle fully unless it is a qa throttle.
