sprocket sizeing
Discussion in 'General Tuning' started by scottdickinson, Feb 21, 2012.
  1. scottdickinson New Member
    Message Count:
    16
    dose anyone know what front sprocket and back sprocket size to use on a aprilia rs50 to get more speed.. iv read up on it but now am confused iv read that a large rear sprocket and small front sprocket is good to use
    but at the moments my aprilia rs50 has a 14 teeth on the front havnt counted the one on the back but its big
  2. Stig Member
    Message Count:
    832
    EXUP1000
    larger rear or smaller front will give more acceleration with a loss on top end. larger front and smaller rear will give more top speed but slow acceleration....to a point on a 50cc.
    From what I've read its std is 12 and 47 which is approx 1:4 ratio. If you drop 1 on the front its almost same as adding 4 on the rear and vice versa.
    If you go too much smaller on the rear the power of a 50CC will not be able to pull the extra load, it'll just bog in so theres not alot of point going for too much more on the top end. A good friend tried this years back on a Suzuki X1 moped and found all this out by trial and error.
    plus.... if you go alot smaller on the front theres a chance the chain will rub on the swingarm pivot/axle point
    either way you go, go for a happy meduim say 1 smaller on the front for acceleration or 3 on the rear
    or maybe 2 larger on the rear for top end
    hope it helps
  3. scottdickinson New Member
    Message Count:
    16
    thank you
    you made it sound so simple i did read on it but two of my m8t couldnt agree about the sizes
    but you have now settle a arguement lol
    iv just read mine should have a 12 on the front as standard but at the moment i have a 14 on it its still crap on topend so i think my mainfold is restricted
    but anyways thanx for your info
Facebook:
