well my alarm came today so im going to try fit it but i need help as im confused could any one tell me some steps/tips for fitting the non-talking version c11 thanks
runner 125 fx hi,cant claim the credit for the diagram was put up for me when i asked the same question.q1 that wire is white,q2 i taped off the grey, pink and blue as there part of the remote start which i did not want as it only turns the engine over for 3-4 seconds and my runner needs longer than this on the button.hope this helps.
runner 125 fx also did not wire to battery.any theif will look there first so wired to the red on ignition(constant live) cheers
fuck, I rememba doing this at 3 in the morning in my alley way with stupid christmas LEDS using them as light, it can be a little bit confusing sometimes, the ignition part was the hardest and also the remote start is fuckin pointless if you have to hold your brake lever/ clutch lever in to start the bike which most of them to as a safety precaution. about as much use as a snooze button on a burgular alarm the novelty of the talking version is gone now tho... embarrising when some old fart rambles on about "please remember to arm the alarm" and a fit blonde walks passed you into tesco's...... :emb: and by the way that blue wire you circled moanss, intercepts that wire that connects to/ or from the electric start button also make sure that you ground the alarm properly to the frame, otherwise youll be changing fuses like a pair of socks..., and when you join wires and things, insulate the wires properly as water will fuck it right it up
well .. i conneted the blue wire to the green and black and the brown to the white ...... the alarm works but not sure if the electric start works as i need a new battery
you should conect it to the wires that it tells you that it is supposed to connect to for your bike, phone up the people that make the alarm ncook security ltd i think theyre called they do over the phone help apparantly also i think you joined that wire to the wrong one, the starter relay wire is usually a BLUE and White one, it runs to the electric start switch from the battery with a fuse along the line by the battery both manual electric and auto start (remote) will work if youve wired the alarm in properly because all your doing is wiring in two circuits into one, like a parellel circuit but i deffinately think youve connected it to the wrong wire tbh. the wire that needs cutting and joing is the blue and white one coming from the start switch (electric start button)
Re: runner 125 fx Hey thats my "drawing" from Runner net??? But that is ok. http://www.gilerarunner.net/e107_files/ ... _alarm.jpg
